Heavy-duty pipe systems
Dissimilar metal pipe systems
Transition to bulkhead unions is one of the traditional methods of sealing.
Roxtec’s alternative solution
Author
Will Hoffman
Pipe sealing specialist Department Business Area Marine & Offshore at Roxtec
Learn more about pipe sealing solutions
Product data
Find ratings, certificates and available sizes in our product database.
