Roxtec proudly introduces the innovative Roxtec SPM™ seal – a patented sealing solution that helps you ensure safety and operational reliability without any downtime or cost related to welding.
The Roxtec SPM™ seal is a light-weight solution that can be used to seal metal pipes against fire, water and gas onboard marine or offshore structures.
The seal is made of highly elastic EPDM rubber and fittings of acid-proof stainless steel. It is quick and easy to install from only one side of steel decks or bulkheads. The structure may range in thickness from 6 to 15 mm. The Roxtec SPM™ seal maintains a tight seal around the metal pipe as well as sealing inside any uneven or irregular opening.
The indicators that show when full compression is achieved are just one example of its safe and user-friendly design.
Pipe seal installation comparison
Do you understand the differences between bulkhead unions, sealing plugs and non-weld Roxtec SPM™ seals? Watch the installation comparison video below and discover why it is important to select the right metal pipe sealing method.
Product data
Find ratings, certificates and available sizes in our product database.
Explore more
Find more content related to Roxtec SPM™ seal
