Oceanbird installs highly efficient wing sails on car carriers to help the shipping world save both fuel and the environment. The first wind-assisted vessel has already crossed the Atlantic Ocean. The ground-breaking Swedish company has chosen Roxtec sealing solutions for the hydraulic hoses. The two main reasons are multi-hazard protection and flexibility.
“The modularity of Roxtec openable seals makes life easier for us. We do not have to know where hoses and cables are to be routed in advance, and we can change hoses and cables whenever we need. The wing sails have the same service life as the vessel,” says Jonas Alván, Head of Transformation and former Product Manager at Oceanbird.
Research project became business
It started as a research project, aiming to explore wind propulsion, with players such as the Swedish Transport Administration, KTH Royal Institute of Technology, and RISE, Research Institutes of Sweden. It turned into a joint venture of technology giant Alfa Laval and Ro-Ro shipping leader Wallenius Lines. Since 2021, Oceanbird has developed wing sails for Ro-Ro vessels and tankers, using technology inspired by aircraft wings.
Cost-savings and climate benefits
The first rigid wing sail to cross the Atlantic is a “wind-assist wing” installed on the car carrier Tirranna. It measures 560 square meters, is tiltable and turns automatically to harness the wind, gain speed and help reduce fuel consumption by up to 10%. Imagine the cost-savings and climate benefits: similar vessels consume 50 tons of fuel per day.
“Shipping by sea is increasing, and the emissions equal the emissions of the aviation industry,” says Jonas Alván. “Important costly efforts are made within alternative fuels, but the wind is free and everlasting, and we can use weather forecasts to select routes.”
Protecting against fire and water
Roxtec seals are used where about 30 hydraulic hoses enter and exit the temperature-controlled machinery house. The seals protect the containerized control systems against fire and salt water, and act as a safety barrier against accidental oil leakage. Roxtec cable seals are also used to secure the control cabinets in the machinery house.
Roxtec performed special fire tests
Roxtec representatives were present onsite during the construction of the wing sail and machinery house to provide technical support and an appreciated installation training.
Roxtec also performed fire and tightness tests with its seals and hydraulic hoses used by Oceanbird in the Roxtec test lab. It all went well. The extensive test report, which was signed and approved by a Roxtec test and certificates engineer and shared with Oceanbird, shows that the solutions meet equivalent marine fire and tightness requirements.
- Flexibility for cables and hoses of different sizes
- Modularity for easy changes, upgrades and retrofit
- Multi-hazard protection
- Installation training onsite
- Technical support, including fire tests
Construction of wing sails for wind propulsion of vessels in Sweden
Companies involved
Oceanbird, co-owned by Wallenius and Alfa Laval – design, engineering and installation
Sealing of hydraulic hose penetrations as well as cable entries in electrical cabinets
A-60 class fire performance
Watertight
Vibration-proof
Roxtec SK transits
Product list
Roxtec SK transit
Transit with extra deep metal frame for welding to the structure.
Extra deep transitMore images
