  2. Sealing solutions
  3. Roxtec mobility seals
Optimize weight, space, and safety.
Roxtec mobility seals for rolling stock are light and compact to save weight and space. Even though they are small safety components, they provide support to rail vehicle manufacturers and operators in their ambitions regarding weight reduction onboard. Every contribution to reduction of the total weight of a rail vehicle can help players in the industry reduce carbon dioxide emissions and fulfill sustainability goals. You can use Roxtec cable, pipe and conduit seals in floors, walls and cabinets in all kinds of trains to ensure protection against fire, water and dust.
Watch this video to learn more about Roxtec mobility seals.
The Roxtec mobility seal product range consists of lightweight yet robust sealing products for cable, pipe, and plastic conduit penetrations. The sealing solutions are based on flexible and well-proven Roxtec modular-based transits but have been optimized with regards to weight, which enables:
  • Speed of installation
  • Safety
  • Strength-to-weight ratio
  • Performance
You get the ingress and fire protection you require while securing weight and space optimization onboard. Therefore, the seals are perfectly suited as a standard high-quality solution for cost-efficient manufacturing and long-term operational reliability in mobility sectors such as rolling stock.
Meeting industry standards
Roxtec mobility seals are thoroughly tested:
  • HL3 in accordance with EN 45545-2 (R22, R23)
  • E30 in accordance with EN 45545-3
  • IP 66 in accordance with IEC 60529
  • Shock & Vibration Category 2 in accordance with IEC 61373
The sealing modules adapt to cables, pipes and plastic conduits of different sizes and can ensure spare capacity for additional cables.
Updated:
