  2. Sealing solutions
  3. Introducing Roxtec CSP cable transits
New Roxtec Cabinet Seal Platform for harsh environments.
With Roxtec CSP cable transits, you can ensure safety through certified multi-hazard protection all while saving time and space. The compact, multi-cable penetration seals are ideal for cabinets and enclosures with high cable density. They are the innovative alternative to traditional cable glands.
Benefit from the Roxtec Cabinet Seal Platform
Roxtec CSP transits are made for harsh environments. They can either include Roxtec standard sealing modules and protect against water, dust, sand and dirt, or Roxtec CM BG™ (bonding and grounding) modules to add an electrical safety feature for armored cables.
Quick to install
The transits are quick to install in cabinets and enclosures because they have integrated compression and very few components – only the acid-proof stainless-steel frame and the sealing modules with Roxtec Multidiameter™. The Roxtec invention for adaptability and flexibility is based on removable rubber layers and ensures a perfect fit for cables of many different sizes.
High cable density
Roxtec CSP transits are compact sealing solutions that help you manage high cable density in a reduced footprint. They are area efficient and available in two different sizes, in which you can seal up to 16 or up to 32 cables in a single cut-out. The design allows you to pass through pre-terminated cables without cutting the connector.
Discover Roxtec CSP transits for harsh environments
Built-in spare capacity
You can benefit from the built-in spare capacity by planning for expansion with additional cables of many sizes, without any need for drilling or punching new holes. In other words, you can add new cables without adding new openings or sealing materials.
There are multiple compartments for cables and sealing modules in the transit. Just open the one you want to add cables to and let the other compartments remain tight.
Product data and ratings
Updated:
