Do you want to prevent water ingress?
Use Roxtec seals to avoid the risk of costly downtime and power outages due to corrosion, damage to equipment or partial discharge.
Roxtec UG™ (underground) solutions for cables and pipes protect your site against environmental ingress in both normal and flood conditions. The seals withstand cable bending forces and are resistant to constant water pressure. Keep your equipment dry and safe by ensuring a long-lasting sealing barrier against flooding, gas, humidity and rodents.
User-friendly flexibility
Roxtec UG™ seals are easy to install even in wet conditions and in environments with running water.
- Available for single or multiple cables and pipes
- Multidiameter™ by Roxtec – adapts to cable and pipe sizes through removable layers
Retention capabilities
The seals are tested and developed to provide excellent cable retention.
- Withstands pull force of up to 15 000 N and a weight load of up to 1 500 kg
- Withstands extreme cable bending
- Can expand up to 5 mm to aid installation and ensure a perfect fit
Tight and resistant
Roxtec UG™ solutions are IP 68 rated. They are tested for constant and catastrophic water pressure. Thanks to their high grade acid-proof stainless steel, they are suitable for the harshest of environments.
- Constant water pressure up to 0.5 bar (5 mH₂O)
- Catastrophic water pressure up to 1 bar (10 mH₂O)
- Gas pressure up to 0.5 bar
- Corrosion and rodent safe
Think first
Roxtec cable and pipe seals keep pump and lift stations in water management watertight and gas-tight. Explore recommended seals for underground entries.
Knock-out sleeve installation
Basic steps of a Roxtec knock-out sleeve installation
RS UG™ seal installation
Basic steps of a Roxtec RS UG™ seal installation
Learn from experts
Are you using control measures like water pumps and dehumidifiers as first line of defense against structural ingress?
Learn how you can avoid humidity in substations through a combination of smart sealing solutions and electronic monitoring.
Partial discharge activity is the root cause of 85 percent of switchgear failures. Learn how you can handle this threat to stable power supply and keep your substation dry by making sure you get it all right from the start.
Read about how to ensure optimum operating conditions from day one.
Operators of electrical substations must avoid structural ingress by handling challenges such as ground settlement, heavy cable load and running water.
Learn how to prevent rodents, water ingress, dust and the risk of partial discharge activity.
Make sure your new substation meet different laws and local and international safety standards.
Read our step-by-step guide on how to improve the substation design phase by adding expertise and adopting innovative sealing solutions.
Numerous application areas
Roxtec UG™ seals are ideal for cables and pipes entering buildings via concrete foundations. They provide excellent cable retention, eliminate flooding and prevent humidity from damaging equipment. You can use them in vaults, duct banks or cable trenches.
- Power
- High voltage power
- Signaling
- Telecom
- District heating
- District cooling
- Water
- Wastewater
- Plastic, steel and isolated pipes
Adaptable and tailor-made solutions
Roxtec UG™ solutions are perfect for use around existing cables and pipes, and the smart design simplifies retrofit. The seals fit into the knock-out sleeve as well as in conduits and core drilled holes. The soft yet firm rubber adapts to uneven openings and ducts. Our openable seals do not suffer from failure in the same way as traditional methods do when the cables or pipes move and expand.
Customized seals
If you have specific needs or face challenges that require special Roxtec UG™ seals, our design and engineering team is ready to help you by creating tailor-made sealing solutions.
Find reliable seals
Here are some examples of solutions from our Roxtec UG™ family.
