Labs and cleanrooms within the pharma, biopharma and biotech sectors need cable and pipe penetrations that are airtight, gastight, watertight and fire rated as well as easy to clean and inspect. The Roxtec LabSeal™ is developed and optimized for such advanced airtight facilities.
Whether you design, build, own or operate these kinds of demanding environments, you are obliged to focus on safety, airtightness and cleanability. You must control the airflow and avoid the risk of unwanted leakage in connection to cable penetrations in walls and ceilings. All passive safety systems like cable and pipe penetration seals must be easy to keep totally clean.
For your airtight environment
The Roxtec LabSeal™ is hygienically designed in accordance with GMP (Good Manufacturing Practices) guidelines. It has an easy-to-clean powder-coated aluminum frame and a smooth surface with drainable edges, integrated compression units and hidden mounting screws. It fits most facilities as it covers the GMP requirements for cleanroom environments.
- Hygienically designed in line with GMP guidelines
- Easy to clean
- For grade A, B, C and D (ISO 5-8) cleanrooms
Safe and clean in every aspect
Additional features make Roxtec LabSeal™ your perfect choice for lab and cleanroom applications. It is lightweight, area efficient and easy to install, maintain and inspect. The transit and its components are tested and approved by various authorities. It has the Fraunhofer certificate (Particle emission Class 1 acc. to 14644-1) and is fire rated for E30. The screws are EHEDG (European Hygienic Engineering & Design Group) approved, and the Roxtec Assembly Gel White is tested for particle emission.
- Lightweight
- Area efficient
- Easy to use, maintain and inspect
"Future included" – ready for expansion
The Roxtec LabSeal™ is designed for assembly with very few components and for attachment without any visible bolt holes in the structure to ensure an airtight installation. As it is a Roxtec product, it is filled with sealing modules with Multidiameter™, the Roxtec invention for adaptability to cables and pipes of different sizes. This simplifies the handling of late design changes and helps installers cope with unpleasant surprises caused by unexpected cable or pipe sizes onsite. This unique feature is also beneficial as it provides optional spare capacity, which makes it possible to plan and prepare for upgrades with additional cables, pipes and equipment.
The Roxtec LabSeal™ is available in pre-configured kits. Explore it further under the Products section.
We are always ready to assist you with our sealing expertise, including safety seals, services and software.
