Do you want to simplify specification, planning, design, installation and management of mechanical service penetrations for cooling infrastructure and process utility systems? With Roxtec, you can easily seal metal and plastic pipes of different sizes, prevent downtime through multi-hazard protection and ensure flexibility for both changes and expansion.
Mechanical engineers around the world face the same challenges: an increasing use of chiller, façade and HVAC pipes combined with higher demands for safety, operational reliability, and upgrades. Roxtec seals provide certified protection, withstand pipe movement, vibration and thermal expansion, and are openable to allow for more pipes.
Specify Roxtec pipe seals – and ensure operational continuity
Prevent leakage, failure and outage. Enable retrofit without demolition.
Sealing pipes in AI data centers
With Roxtec airtight pipe seals, you can increase energy efficiency and secure liquid cooling technology. Imagine that one standard solution is enough. You handle coolant distribution unit interfaces, cold-supply and warm-return pipe entries, and water treatment plant pipes.
More on pipe seals for AI data centers
Managing piping in laboratories
Meet new demands for safe lifecycle performance in labs and pharmaceuticals in a cost-efficient way. Secure pipe penetrations for cooling water, process utility systems, critical mechanical services, and water treatment with Roxtec mechanical entry seals.
Read more about pipe seals for labs
Securing semiconductor plants
Make sure the utility infrastructure in semiconductor facilities and gigafactories is resilient. Roxtec seals can provide tight penetrations along the entire water treatment infrastructure as well as for process utility systems and critical building services.
More on pipe seals for semiconductor fabs
Prevent leakage in water and wastewater facilities
Official regulations require reliable public services driving investment in water and wastewater infrastructure. Secure pump stations, pump rooms, and underground valve chambers with Roxtec seals, since they provide a barrier against water ingress, rodents and aggressive gases.
Explore pipe seals for water management
Seals for metal and plastic pipes
Roxtec seals are available for both metal and plastic pipes. The unique flexibility and tolerance help you handle pipe layout changes, incorrect opening sizes, non-uniform annular gaps and poorly positioned pipes – and ensure fire protection for both metal and plastic pipes.
Discover Roxtec metal and plastic pipe seals
Digital tools for mechanical seals
Use Roxtec software to stay in control throughout the seals’ long service life. Roxtec Transit Designer™, for example, makes it easy to design hundreds of pipe seals in just a few minutes and select the right pipe seal with the right certification for the application.
Learn more about Roxtec software
FAQ
A pipe penetration seal closes the annular gap where a pipe passes through a wall, floor, slab or enclosure. It maintains the required performance of the barrier. Depending on location, the seal must match the barrier's fire resistance, watertightness, gas-tightness and airtightness. Mechanical seals use a frame or sleeve, rubber sealing modules or a seal body sized to the pipe, and compression that closes the gap. Unlike traditional mortar or mastic-based penetration seals, Roxtec seals are designed to accommodate pipe additions, movement, and future maintenance without removing and replacing the sealing material.
A specification should define the barrier, the pipe, and the performance the seal must demonstrate through testing:
- Barrier type, material and thickness
- Opening method (core-drilled hole, cast-in sleeve, welded sleeve or frame) and its size tolerance
- Pipe material, outer dimension, wall thickness and insulation
- Fire classification to EN 13501-2, tested to EN 1366-3, including pipe end configuration or the applicable fire-stop rating tested to UL 1479/ASTM E814 in North America
- Water pressure in bar, gas-tightness and airtightness
- Expected thermal movement and vibration
- Spare capacity for future pipes
- Inspection and documentation requirements
Ask for the classification report, not only the data sheet. The report states exactly which pipes, insulation and walls the rating covers.
Pipe penetration seals are tested to EN 1366-3 and classified to EN 13501-2. The classification gives integrity (E) and insulation (I) in minutes, for example EI 120. For pipes, it also states the pipe end configuration used in the test: U/U, C/U, U/C or C/C. U means uncapped and C means capped, on the fire exposed and non-fire exposed sides of the test specimen. Open systems such as drainage and vent stacks typically require U/U. The rating applies only to the tested pipe materials, size range, wall thickness, insulation and supporting construction.
Yes. The fire classification is valid only for the insulation configuration that was tested. EN 1366-3 defines insulation by material, thickness, and configuration. Sustained insulation (CS, LS) runs through the penetration seal. Interrupted insulation (CI, LI) stops at the seal. C means continuous insulation along the pipe and L means local insulation. Elastomeric insulation behaves differently in fire than mineral wool insulation. On chilled water pipes, the vapor barrier must also remain continuous through the penetration; otherwise, condensation can form within the seal.
Design for the highest groundwater, flood or surcharge level at the penetration, plus a safety margin. One bar equals about 10 metres of water head. Ask for the tested pressure and test duration. Confirm the test matches the installed case: wall material, opening method and pipe material. In pump stations and underground valve chambers, also check resistance to hydrogen sulphide, other sewer gases and rodents.
Gaseous suppression only works if the room holds the agent concentration for the full hold time, typically 10 minutes. Room integrity is verified with a door fan test to ISO 14520-1 or NFPA 2001. Every unsealed or damaged pipe penetration adds leakage area. Specify gas-tight seals for CDU, liquid cooling and chilled water penetrations into protected rooms. The seals should be openable for new pipes and resealable to the same tightness without new material. Retest room integrity after changes.
Chilled water and heating pipes expand and contract with every temperature cycle. Pumps and chillers transmit vibration. Rigid seals such as mortar or grout crack or lose adhesion under repeated movement, which opens a leak path. Elastic rubber seals absorb limited axial and lateral movement and dampen vibration. This also reduces structure-borne noise. Specify the expected movement and ask for the tested limits. In semiconductor fabs, decoupling pipes from the structure also helps protect vibration-sensitive tools.
Plastic pipes (PP, PE, PVC-U, PE-X and multilayer) soften and burn away in a fire, leaving an open hole. The seal must close that hole, usually with intumescent material that expands and crushes the pipe. Metal pipes stay in place but conduct heat. This can exceed the temperature limit on the unexposed side (the I criterion), so metal pipes may need insulation on either side of the seal. Use a seal tested for the specific pipe material, size and wall thickness. Roxtec RS PPS seals are tested for plastic pipes.
Openings are often cast or drilled before final pipe routes are fixed. As a result, pipes end up off-center and opening sizes vary. A round seal must close a non-uniform annular gap without losing tightness. Check the opening size range the seal accepts, the pipe size range per seal, and the maximum pipe offset. Multidiameter™, the Roxtec solution based on sealing modules with removable layers, lets one seal adapt to a range of pipe sizes on site.
Yes, if the seal is openable. Split modules and seal bodies are installed around existing pipes without cutting or draining them, so they suit retrofit in live facilities. Solid modules build in spare capacity that can be adapted for new pipes later. To add a pipe, decompress the seal, adapt a module and recompress. The seal keeps its classification only if it is reassembled according to the installation instructions. Record each change for inspection.
Checklist for your pipe penetration seal selection
- What are the required protection levels? A tested and certified seal can help you reduce the risk of water ingress in combination with multiple other hazards. It can also reduce the risk of installation errors, delays, and maintenance issues, and at the same time simplify compliance with project requirements and safety standards.
- What are the materials, conditions and requirements? You need to know pipe materials and dimensions, wall and floor construction details and environmental conditions as well as inspection and maintenance requirements.
- Are there any retrofit or expansion needs? Cooling systems expand, utility networks grow, and facilities are upgraded. Openable seals can be installed around existing pipes, making them suitable for retrofit projects and upgrades. You can add pipes for expansion without major reconstruction. This can reduce downtime and lifecycle costs.
