  2. Application areas
  3. Modular seals for modular offsite construction projects
Optimize safety and scalability.
Roxtec seals for cables, pipes and conduits provide more than certified protection against multiple risks. Our technology enables a range of solutions to cover performance requirements, suitable for different modular structures and quick expansion needs. Here is why it is smart to use our seals in the urgent green transition towards a properly powered planet.
If you are involved in the rapidly expanding modular offsite business, you know that speed and safety count. The winners are the ones who manage to construct, deploy, and deliver in a streamlined manner. Therefore, an increasing number of industry players turn to Roxtec to get flexible sealing solutions that combine certified performance and ease of standardization for scaled manufacturing.
Roxtec seals are proven ideal for clean energy projects. We have an extensive track record as sealing experts within renewables and as supplier to battery energy storage and green hydrogen projects as well as to process industries. We see this demand grow with developments such as small modular reactor (SMR) projects building on our extensive nuclear power experience. The seals provide built-in spare capacity and adapt to varying cable and pipe sizes, so they are always ready to welcome additional services.
Design - Installation - Operation
Tightness – Fire protection – EMC/Ex
Bolt – Cast – Weld
Efficiency – Reliability – Flexibility
Design
Tightness – Fire protection – EMC/Bonding and grounding/Ex
You can always secure the verified performance you need with Roxtec seals. Simply select the right solution for protection against ingress, fire, EMI, or the risk of explosion, or for ensuring bonding and grounding by using our software Roxtec Transit Designer™.
Installation
Bolt – Cast – Weld
There are Roxtec sealing solutions available for attachment by bolting, casting, or welding. Install them in modular panels, steel, or concrete walls in any containerized or prefabricated modular buildings or kiosks.
Operation
Roxtec seals are fit for purpose and ensure long-term operational reliability. They are openable, adaptable to cables and pipes of different sizes and provide spare capacity for easy upgrades and future needs.
