  2. Sealing solutions
  3. Roxtec SLA sealing solution
Designed to eliminate welding
Roxtec SLA sealing solution with adaption sleeves.
The ongoing modernization and digitalization onboard ships, vessels and offshore units require smart solutions for retrofit and upgrades – such as this new non-weld solution.
In order to help the marine and offshore industry players handle the demands of the fast development, for example when it comes to efficient installation of new communication systems, we present the Roxtec SLA sealing solution.
The Roxtec SLA solution includes well‑proven Roxtec R transits, RS seals, and the Roxtec H2 seal, all combined with adaption sleeves. It simplifies the addition of cables late in a project and enables upgrades and repair work without welding.
Easy installation
You simply drill a hole in the structure using a hole saw. The sleeve is threaded, attached with a counter nut and designed to fit in standard hole saw openings.
  • Eliminate welding
  • Minimize hole cutting
  • Reduce fixation work
Certified protection
  • A-Class division fire rating
  • 2.5 bar water-tightness
Download
Read more about the Roxtec SLA sealing solution.
Interested in a demo?
Let's plan for a demo session. Just enter your details.
