Welded preference
Our welded solutions are developed and tested to meet the specific requirements of the rolling stock industry.
Fire rated for 30 or 60 minutes.
Cables
Single
Roxtec RS seal with SL RS (E 30)
Multiple
Roxtec C LW/K transit (E 30)
Roxtec S transit (EI 60)
Roxtec SF transit (EI 60)
Roxtec SK transit (EI 60)
Roxtec R transit with SL R (E 30)
Metal pipes
Single
Multiple
Plastic conduits
Single
Roxtec RS PPS/S seal with SL (EI 60)
Multiple
Roxtec S with RM PPS (E 60)
Roxtec SF with RM PPS (E 60)
Roxtec SK with RM PPS (E 60)
Roxtec RS with SL RS is a seal with metal sleeve for single cables or pipes. The entry seal has two halves with removable layers making it adaptable to cables and pipes of different sizes.
Roxtec S is a multi-cable and pipe transit available in different materials and with a single or various combinations of openings.
Roxtec SF is a cable and pipe transit with metal frame and flange. It is available in different materials and with a single or various combinations of openings.
Roxtec SK is a cable and pipe transit with extra deep metal frame. It can accommodate stiff cables that do not pass in a straight angle.
Roxtec RM sealing modules are 60 mm deep and easy to adapt to cables and pipes of many sizes.
Roxtec R with SL R is a cable and pipe transit with sleeve for use in round holes. The compression is integrated in the transit frame so it seals by expansion.
Roxtec RS PPS is a sealing kit for large single plastic pipes. It consists of two Roxtec RS seals and an intumescent-based sealing strip that wraps around the plastic pipe in between.
Roxtec RM PPS is a sealing module for plastic pipes. It includes intumescent material that expands in case of fire.
Roxtec C LW/K are compact, lightweight and strong transits for multiple cables and pipes. The C LW version has a 30mm deep frame and the C LWK a 60mm deep frame. They are attached by welding.
Bolted preferences
We offer both regular-sized and compact solutions for bolted structures. They are designed to fit rolling stock applications and tested to meet the industry standards.
Cables
Single
Roxtec C RS SLO seal (E 30)
Roxtec RS seal with SLF RS (E 30)
Multiple
Roxtec C LH transit (E 30)
Roxtec GH transit (El 60)
Roxtec CF 24 transit (E 30)
Roxtec CRF (E 30)
Metal pipes
Single
Multiple
Roxtec R transit with SLF R (E 30)
Roxtec CRF (E 30)
Plastic conduits
Single
Roxtec RS PPS/S seal with SLF (EI 60)
Multiple
Roxtec GH with RM PPS (EI 60)
Roxtec CRF (E 30)
Roxtec CF 24 (transit) is an openable entry seal for cabinets and enclosures. It has an aluminum frame with integrated compression and Roxtec CM PPS (plastic pipe sealing) modules for efficient fire protection.
Roxtec CRF (transit) is a lightweight sealing solution for cables, pipes and plastic conduits with space saving design.
Roxtec GH is a cable and pipe transit for bolting onto steel or sandwich walls/floors. It allows for high packing density.
Roxtec C LH (transit) is an area efficient, lightweight and strong transit for multiple cables and pipes. The transit frame is produced in aluminum and is attached to the structure by bolting.
Roxtec C RS SLO (seal) is a lightweight and strong sealing solution for single cable and pipe entries in cabinets, enclosures, and equipment. It consists of a Roxtec C RS seal and a Roxtec C SLO sleeve.
Find more product information on roxtec.com/solutions. If you have questions or wish to order a customized solution, please contact us.
