  2. Sealing challenges
  3. How to eliminate welding
How to eliminate welding when sealing metal pipe penetrations
Heavy-duty pipe systems
Dissimilar metal pipe systems
Transition to bulkhead unions is one of the traditional methods of sealing.
Roxtec’s alternative solution
Author
Will Hoffman
Pipe sealing specialist
Business Area Marine & Offshore at Roxtec
Will Hoffman
Product data
Find ratings, certificates and available sizes in our product database.
Roxtec SPM™ seal
Roxtec SPM™ seal
fire rated.svg
watertight.svg
gas-tight.svg
Seal for metal pipes for use when welding is not allowed, recommended or desired.
Easy installation without welding
Fire
Tightness
  • Gas: 0.67 bar (catastrophic)
  • Water: 1 bar (catastrophic)
