Roxtec offers a range of digital ordering options designed to make it easier to do business with us – whenever and wherever it suits you.
Flexible digital ordering
Through My Roxtec, you can choose the way of working that fits your needs: from placing orders directly or requesting and managing quotations to using quick ordering for faster handling. All options are part of our digital ordering approach, aiming to give you flexibility while ensuring a consistent and efficient experience.
Together, these solutions help simplify your daily work, provide better overview and control, and support a smoother interaction with Roxtec.
Explore features
Roxtec e-commerce
What is e-commerce?
Roxtec e‑commerce makes it easy to purchase the right sealing solutions for your projects. With smart features like Quick order, you can place bulk orders in seconds, while Repeat order simplifies recurring purchases by letting you duplicate previous orders with just a few clicks. In e-commerce, you can also quickly check what we have in stock and view your pricing.
Enjoy a streamlined process that saves time, reduces errors, and keeps your workflow efficient. Whether you are managing large projects or buying spare parts, e-commerce is designed to make shopping online simple, fast, and available whenever you need it.
Get started with e-commerce
E-commerce is a part of My Roxtec and available in selected markets. Follow these steps to get started:
- Register a Roxtec account and navigate to My info in the top right menu.
- Follow the steps to setup a customer account.
- When your request is approved, you will have access to e-commerce and be able to add items to cart in the top right menu next time you refresh the page.
Repeat order
What is Repeat order?
Repeat order saves time and reduces effort when you have recurring needs. Instead of starting from scratch every time, you can duplicate a previous order and adjust it if necessary. This is ideal for projects that require the same products repeatedly or for organizations with standardized configurations.
By reusing past orders you minimize manual work and reduce the risk of errors. With just a few clicks, you can confirm your selection and proceed to checkout. Repeat order helps you maintain consistency across projects and keep your operations running without delays.
Get started with Repeat order
Repeat order is a part of My Roxtec and available to all users with e-commerce activated. You can find Repeat order by opening the details for a previous order in “My orders”. Scroll down to the end of the details and you will find the option to Repeat order.
Quick order
What is Quick order?
Instead of searching or adding products one by one to your cart, you can insert articles from an Excel template or paste individual article numbers and quantity to add multiple products in seconds.
This feature is perfect for large projects or recurring purchases where time and accuracy are a priority. By streamlining the process, Quick order helps you reduce manual work, minimize errors, and keep your procurement workflow moving smoothly. With Quick order, you stay in full control and can move swiftly to delivery without unnecessary steps.
Get started with Quick order
Quick order is a part of My Roxtec and available to all users with an e-commerce account. Once you are logged in to My Roxtec and your access has been approved, you will see additional e‑commerce options in the top right corner of the screen.
Punch out
What is Punchout?
With Punchout, you can connect your procurement system directly to the Roxtec e-commerce for real-time access to products and pricing. This gives you up-to-date information and a smooth procurement experience. You simply select what you need and send the cart back to your system for approval and purchase, no extra steps required.
The Punchout experience is standardized to guarantee smooth integration. Punchout requires a compatible e-procurement system that supports protocols such as cXML or OCI. If you are unsure which options work best for your organization, feel free to contact us via the form below.
Punchout does not replace your company’s procurement approval process, it simply streamlines product access. Your internal approval workflows remain intact. The initial setup involves a joint effort and requires coordination between Roxtec and your IT team to configure and validate the integration.
Get started with Punchout
After the initial contact, Roxtec will provide technical documentation and requirement specifications for the Punchout integration. This typically includes:
- Exploring technical prerequisites
- Development in a test environment
- Validation and approval
