- Comunicado de prensa
Rittal Belgium supplies shelters and cabinets to Infrabel already equipped with Roxtec seals. The seals adapt to cables of different sizes and provide spare capacity. General Manager Koen Wolfcarius says: "By offering Roxtec, you keep the flexibility for the last phase of the engineering. Roxtec seals also give perfect protection against environmental influences."
Watch a movie about Roxtec seals in Belgian rail infrastructure.
Captions:
- Roxtec provides complete sealing solutions for rail infrastructure and safe operations.
- Roxtec cable and pipe seals are tested and certified to protect against multiple risks.
