  3. New firestop for cable bundles
  • Comunicado à imprensa
Publicado:
In order to meet the huge and unsatisfied demand for efficient firestops for entire cable bundles, cable and pipe transit specialist Roxtec introduces the GK Multi-cable fire collar.
"This fire collar is designed for use in entries with high cable density in decks and bulkheads in fire rated divisions above the waterline," says Roger Johansson, Executive Vice President and Business Area Manager Marine & Offshore at Roxtec. "It is certified to A-60 marine fire rating and easy to use when you want to ensure protection onboard ships and vessels."
The GK Multi-cable fire collar is tested according to type approval test guidelines as well as to SOLAS/IMO regulations, and it is both RoHS and REACH compliant. It is quick, easy and safe to use with multiple cables, entire cable bundles and busbars.
"It is cost-efficient thanks to its great fill ratio and since you do not have to separate any bundled cables," says Roger Johansson.
Images
The GK Multi-cable fire collar is a new transit designed for marine applications.
Download
Download
Comunicados à imprensa
Fique à vontade para ler e utilizar as informações em nossos últimos comunicados de imprensa.
