  3. Roxtec presents new plastic pipe seals for aluminum structures
  • Press release
Certified protection
Seals for plastic pipes
Media contact
Roger Johansson
Executive Vice President
Marine & Offshore Oil & Gas
Karlskrona, Sweden
Roger Johansson
