  3. PR - Roxtec SPM™ seal certified
The Roxtec SPM™ seal has now received its MED certificate and type approval certificates
  • Press release
Updated:
Quick and easy to install
Media contact
Roger Johansson
Executive Vice President
Marine & Offshore Oil & Gas
Karlskrona, Sweden
Roger Johansson
