  2. My Roxtec
  3. Explore Punchout
Explore Punchout
Explore Punchout
What is Punchout?
With Punchout, you can connect your procurement system directly to the Roxtec E-commerce for real-time access to products and pricing. This gives you up-to-date information and a smooth procurement experience. You simply select what you need and send the cart back to your system for approval and purchase, no extra steps required.
The Punchout experience is standardized to guarantee smooth integration. Punchout requires a compatible e-procurement system that supports protocols such as cXML or OCI. If you are unsure which options work best for your organization, feel free to contact us via the form below.
Punchout does not replace your company’s procurement approval process, it simply streamlines product access. Your internal approval workflows remain intact. The initial setup involves a joint effort and requires coordination between Roxtec and your IT team to configure and validate the integration.
Get started with Punchout
After the initial contact, Roxtec will provide technical documentation and requirement specifications for the Punchout integration. This typically includes:
  • Exploring technical prerequisites
  • Development in a test environment
  • Validation and approval
Interested in Punchout?
Fill in the form and we will contact you.
