  2. Sealing solutions
  3. New: Roxtec knock-out frame transit – KOF
Use it for pre-sealing, sealing and fire protection.
With the Roxtec knock-out frame transit, KOF, you can ensure water ingress protection during the construction phase – before routing cables and pipes. Whenever you want, you add cables, pipes and sealing components that also bring fire protection. Watch the video below to discover the innovative features.
Watch video to discover the innovative features.
Use the rectangular Roxtec knock-out frame transit to form an efficient barrier in concrete structures. The cast-in frame has a knock-out plate that remains tight until it is time to install your cables, pipes and sealing components. It is designed for Roxtec sealing solutions. In this way, the builder can leave a dry and protected site – with built-in spare capacity both for last-minute changes and future expansion needs.
Lightweight recyclable plastic
The frame is made from recyclable ABS plastic and designed for cast-in-place or prefabricated concrete walls. It is a lightweight, corrosion free and non-magnetic alternative to cast-in steel frames enabling a reduction of the CO2 impact of the construction.
Adaptable to wall thickness
The KOF depth of 100mm (4”) can be adjusted to fit the wall thickness and thereby eliminate the need for casting molds. You just add the right number of 50mm (2”) KOF adapters and attach the frame with nails, screws, glue or magnets to the form work.
Area efficient clusters
Thanks to the integrated connection function, you can form space efficient frame combinations in any direction to fit your needs. The frame can also work as transportation protection when producing prefabricated shelters and kiosks.
Ensuring fire protection
The Roxtec knock-out frame with Roxtec blue sealing components then form a fire rated and watertight transit for multiple cables. You ensure safety and operational reliability while preparing your project for future upgrades and regulations.
You can also use the Roxtec knock-out frame with black Roxtec UG™ sealing components for complete watertightness underground. Discover that version here.
Product data
Continue to the Roxtec product section to learn more about the sealing solution. You will, for example, find ratings, certificates, sealing component data and installation instructions.
Updated:
