  3. Efficient multi-hazard protection of special vehicles
Wong Fong Engineering in Singapore prefers Roxtec cable seals.
The end-customer wanted their special vehicles to withstand overpressure and electromagnetic interferences as well as water and dust ingress. The vehicles must also be easy to upgrade. Wong Fong Engineering managed to meet all the requirements by using Roxtec cable entry seals.
The specific requirements were first related to the internal pressure within the vehicle, necessitating cable sealing solutions capable of withstanding these conditions, and then also to EMI protection. The cable glands and other sealing solutions that had been used up until then were unable to fulfill the new requirements. Hence, the engineers of Wong Fong Engineering evaluated the Roxtec sealing system’s capability of ensuring full compliance. The result was perfect for the end-customer.
“Roxtec is very supportive”
After testing many different methods, Wong Fong Engineering is very satisfied to have finally found Roxtec. With one single sealing solution, they can now ensure overpressure control, EMI protection and ingress protection. They are also happy with the prompt technical assistance from Roxtec which helped them manage the process and meet the short turnaround lead time.
“Roxtec is very supportive, no matter if it is product selection, component selection or technical support. I liked how we had the discussion between us and our account manager, Gregory, because he is very willing to make a trip down to support us and constantly following up through phone calls and visits,” says Mr. Wong Wei Syuen, Mechatronics Engineer at Wong Fong Engineering.
Quick to install, easy to upgrade
The engineers find Roxtec seals easy to install. They now save at least 50% of maintenance time. Most important is the built-in spare capacity: Roxtec systems allow for straightforward addition of cables, without the need to drill a lot of holes during installation. This simplifies expansion or modification. And the split seal design eliminates the need for cutting off and reattaching connectors.
“Roxtec is one of our suppliers who is always very responsive, on the edge, and ready whenever we call them. It has been a very good experience working with Roxtec,” says Mr. Tan Yinglong, Assistant Principal Engineer at Wong Fong Engineering.
"Roxtec is always very responsive, on the edge."
Mr. Tan Yinglong, Wong Fong Engineering
  • Multi-hazard protection
  • Quick and easy installation
Integration and modification of special vehicles in Singapore
Companies involved
Wong Fong Engineering (1988) Pte Ltd – design and engineering
Sealing of cable penetrations
• Pressure control
• EMI protection
• Ingress protection
Roxtec CF 8/32 EMC transits and Roxtec CF 16 transits
