Roxtec SPM™ seal
Seal for metal pipes for use when welding is not allowed, recommended or desired. Roxtec SPM™ seal ... seal SPM 39 1x (8.0-12.0) 1x (0.315-0.472) 49 1.929 39 - 43 1.535 - 1.693 0.14 0.31 167591 -
Roxtec SPM™ seal
The Roxtec SPM™ is a non-weld, light-weight seal for any kind of metal pipe. It is installed from one ... which may range in thickness from 5 to 15 mm. SPM 39 8 - 12 0.315 - 0.472 39 - 43 1.535 - 1.693 -
Roxtec SPM™ seal in additional sizes
productnews Roxtec SPM™ seal in additional sizes The innovative non-weld sealing solution for single ... pipes, and also down to 8 mm in diameter. The Roxtec SPM™ seal has been extremely well received by shipbuilders -
Roxtec sealing solutions in 3D CAD library for CADMATIC
pressrelease Roxtec now offers a 3D CAD library of cable and pipe seals for the software CADMATIC Roxtec sealing ... sealing solutions in 3D CAD library for CADMATIC Media contact For further information, please contact: -
The Roxtec SPM™ seal certified and approved
productnews The Roxtec SPM™ seal certified and approved The new non-weld Roxtec SPM™ seal for metal pipes ... certifications can be found under Solutions & Products. The Roxtec SPM seal can be used with any kind of metal -
Roxtec SPM™ seal certified for aluminum structures
productnews Roxtec SPM™ seal certified for aluminum structures Further scope is added for the innovative ... innovative Roxtec SPM™ seal. The non-weld metal pipe sealing solution is now certified for use in aluminum -
Installation of round sealing solutions
Roxtec installation of round sealing solutions Round single penetration seals Round multiple penetration ... penetration seals Roxtec, installation, round, single, multiple, seal, penetration, requirement Watch a -
Installation of rectangular sealing solutions
Roxtec installation of rectangular sealing solutions Cast rectangular frames Bolted rectangular frames ... frames Roxtec, installation, rectangular, sealing, penetration, requirement Watch a video to see best -
Roxtec UG™ – underground sealing solutions
Underground seals for protection against constant water pressure RS UG™ seal installation Knock-out ... Knock-out sleeve installation Roxtec UG™ solutions Basic steps of a Roxtec RS UG™ seal installation Basic steps -
The sensational SPM is here!
sensational SPM is here! Would you like to seal your pipes against fire and water – without welding? SPM promo ... promo video Well, now you can. Roxtec proudly introduces the innovative Roxtec SPM™ seal. It is a non-weld
Page not found
Maybe you were looking for something specific within Roxtec? Here are some suggestions:
