This seems to be your market:
  1. In focus
  2. Roxtec SPM™ seal
  3. How to eliminate welding
How to eliminate welding when sealing metal pipe penetrations
Heavy-duty pipe systems
Dissimilar metal pipe systems
Roxtec’s alternative solution
Author
Will Hoffman
Pipe sealing specialist Department Business Area Marine & Offshore at Roxtec
Will Hoffman
