  3. Pipe penetration seals
Upgrade your pipe penetration seals
Move away from outdated pipe sealing methods.
Why are shipyards, owners and engineering companies around the world specifying Roxtec seals as their standard solution for pipe penetrations? Because we challenge the traditional sealing methods and offer a superior alternative. Let us show you how.
Roxtec sealing solutions for pipes
Roxtec seals are perfectly designed to protect pipes passing through fire rated or watertight divisions. They offer huge benefits when compared to compounds, sealing plugs and bulkhead unions. Do you need to seal metal pipe penetrations or plastic pipe penetrations, or both? Are you searching for an efficient non-weld sealing solution? We invite you to browse our selection of different sealing solutions.
How to handle pipe sealing challenges
Learn how to overcome common challenges when it comes to sealing pipe penetrations on ships and offshore platforms.
Solve your problems by using Roxtec
Certified protection
Resistant to fire, gas and water.
Easy installation
Quick, clean and a single-sided procedure.
Non-weld options
No need for welding or hot work permits.
Sleeve efficiency
No need for long and heavy sleeves.
Pipe integrity is maintained
No need for unwanted joints, couplings or pipe material interruptions.
Lightweight transits
Reduction in weight for improved fuel efficiencies.
Flexible for any pipe size
Reduction of items and articles in stock.
Efficient retrofitting
Simplified reinstallation during repairs.
Ready for upgrades
Built-in spare capacity for extra pipes.
Perfect for standardization
Review your shipyard standard - now.
Download our pipe seal selection guide
Thank you!
