Roxtec multi-cable and pipe transits are beneficial for OEM integrators supplying systems in deckhouses, shelters and containers to vessels and offshore units. A containerized solution onboard a ship or offshore unit falls under the same classification rules as decks and bulkheads and all transits need to be type approved. With Roxtec seals, you can ensure certified protection from the plant to the shipyard – and to any remote area offshore. By being openable and adaptable to cables and pipes of different sizes, our sealing solutions enable a modular plug-and-play approach.
Our penetration seals are recognized worldwide for being the most thoroughly tested and certified in the marine and offshore industry. They provide A60/A0 and H60/H0 fire protection ratings and pressure ratings as well as solutions for Ex and shielded areas. They prevent humidity inside deckhouses, shelters and containers, resist corrosion and withstand vibration while providing excellent cable retention to extend cable and system lifetime. As an integrator, you gain a competitive advantage by delivering completely protected containers that help ensuring operational reliability.
Standardize with Roxtec
Whether you prepare containers with systems for HVAC, scrubber, fire protection or propulsion, or for water treatment, purification or ballast, our seals help you meet class requirements. If you choose Roxtec as global partner and standardize with our seals, you ensure efficiency and simplicity.
Optimize flexibility
Our seals allow for high cable density – but require very few openings in the deckhouse structure. When it is time to install the containerized system and to secure structural integrity, it is already prepared with openable seals. The seals adapt to the actual cable or pipe sizes thanks to Multidiameter™, the Roxtec invention for adaptability based on sealing modules with removable rubber layers.
Does Roxtec sound like a solution for your deckhouses?
Area efficient sealing
Roxtec sealing solutions save space and weight in deckhouses, shelters and containers.
Read more
Modular scalability
Our solutions are perfectly suited for retrofit or expansion of modular and scalable projects.
Read more
Meeting requirements
With Roxtec cable and pipe transits, you know you meet class and customer requirements.
Read more
Marine track record
We have a long history of providing standard cable and pipe transits to shipyards worldwide.
Read more
Offshore sealing experts
Learn more on how Roxtec contributes to safe operations within oil and gas offshore projects.
Read more
Customized solutions
Our design engineers and sealing experts assist you and tailor transits in line with project needs.
Read more
Cable and pipe transits
Explore the Roxtec product portfolio. We provide seals allowing for cost-efficient standardization.
