- Press release
DSME, Daewoo shipbuilding and marine engineering in Geoje, South Korea, uses an online engineering tool from Roxtec to reduce risk and save time. The Roxtec Transit Designer™ simplifies the selection of sealing solutions as well as the design of cable and pipe transits.
"It is a very compelling tool. Also, it is an ideal solution for significant cost-savings," says engineer Yongjun Lee who designs for large projects such as the Ichthys FPSO.
Mr. Lee is one of thousands of satisfied users of the web-based application. Before the Roxtec Transit Designer™, he used a non-standardized program when working with multi-cable transits:
"There was no proper tool for calculation of material take off when it came to multi-cable transit accessories before the Roxtec Transit Designer™. In some cases the result was not accurate, so I had to make a rough manual calculation. It caused several problems: delays, inaccuracy, lower reliability of the design team and frequent issues in additional orders.
Mr. Lee has a very good experience of the Roxtec Transit Designer™:
"It is really helpful. I can use the program to drag and drop any existing data such as multi-cable transit data or cable schedules and quickly get to see the accurate result. Also, it is designed for easy use for any beginner."
Media contact
Ola Weidenberg
Executive Vice President
Marketing
Karlskrona, Sweden
