  3. One cable seal for all transportation infrastructure projects
Prevent downtime caused by water ingress and rodents.
When you design railways, ports, airports, road tunnels and bridges, you face the same demanding sealing challenges.
Humidity, water and flooding are serious threats today, and will probably be even worse tomorrow. You also know that rats and pests constantly enter vital areas and cause costly damage to crucial equipment.
But keep calm. There is a solution that you can use as your standard seal for all risky openings and entries for cables, pipes, and conduits in all your infrastructure projects. It is the Roxtec sealing system.
What kind of project are you currently working on? Our universal solution can cover also specific needs.
