Evaluate before selecting your metal pipe seals
comparison Evaluate before selecting your metal pipe seals Read this comparison analysis first. 4/24/2020 -
Protect your metal pipe penetrations with Roxtec seals
Protect metal pipe penetrations with Roxtec seals metal pipe penetration, metal pipe seal Seal your pipes ... pipes without welding Roxtec non-weld transits for metal pipe penetrations maintain deck and bulkhead fire -
Fassmer Shipyard selects Roxtec pipe seals
shipyard standard with Roxtec pipe seals Roxtec, Fassmer, shipyard, standard, pipe, penetration, deck, ... bulkhead, seal, certified, protection, fire, gas, water, flexibility, save, space, SPM, non-weld, welding -
Knowledge library
Roxtec knowledge library is a collection of know-how in sealing Roxtec, knowledge, library, know-how ... know-how, cable, pipe, sealing, testing, protection, prevention Explore the Roxtec sealing system and product -
Roxtec SPM™ seal
Seal for metal pipes for use when welding is not allowed, recommended or desired. Roxtec SPM™ seal ... seal SPM 39 1x (8.0-12.0) 1x (0.315-0.472) 49 1.929 39 - 43 1.535 - 1.693 0.14 0.31 167591 -
Zurich Airport selects Roxtec seals
Roxtec seals protect Zurich Airport against multiple hazards Zurich, airport, seal, cable, pipe Zurich ... Zurich Airport selects Roxtec seals – Zurich, Switzerland Zurich Airport selects Roxtec for expertise -
Roxtec cable and pipe seals in FORAN CAD system
and pipe seals in ship design software system FORAN Roxtec, cable, pipe, seal, 3D, CAD, library, ship ... system With the Roxtec 3D CAD library, you can select and integrate Roxtec sealing solutions for cables -
Roxtec SPM™ seal
The Roxtec SPM™ is a non-weld, light-weight seal for any kind of metal pipe. It is installed from one ... one side of the metal structures which may range in thickness from 5 to 15 mm. SPM 39 8 - 12 0.315 -
Roxtec presents a non-weld sealing solution for metal pipes
pressrelease Roxtec presents a non-weld sealing solution for metal pipes Media contact For further ... johansson@roxtec.com Cable and pipe seal manufacturer Roxtec launches the Roxtec SPM™ seal. It is a light-weight -
Poltramp Yard selects Roxtec non-weld seals
Yard selects Roxtec non-weld seals Poltramp Yard S.A. in Świnoujście, Poland, used the new Roxtec SPM ... SPM seal for the BoDo Constructor – a newly built cable laying barge-pontoon. Poltramp Yard needed to seal
Page not found
Maybe you were looking for something specific within Roxtec? Here are some suggestions:
